LB Aluminium Push Button with White Light 250V Ø19mm Black
Push Button
White11NO1NC
Reference 17171
Bon à savoir
1NO1NC type button with white indicator light. Operates from a monostable mechanism.
€6.50Tax incl.
2 years warranty
Available now
  • Paiement sécurisé
Ce qu'il fait
PUSH BUTTON
1NO1NC 250V
LB Bouton Poussoir Aluminium avec Cercle Lumineux Blanc 9-24V Ø19mm Noir
The connectors dedicated to the signal / power supply are gold plated and can support a voltage of 250V / 3A. Those dedicated to the power supply of the indicator light (LED) can accept voltages between 9 and 24V.
An ideal part for your projects, DIY assembly, to repair / improve an existing device or build a control panel from scratch.
Schéma bouton poussoir
1 Connector PBT+GF20 (V0)
2 H65 Silver / Gold plated pin
3 Microswitch
4 Contact: Silver tin oxide
5 Base seat: V0 flame retardant
6 Locking hook
7 Non polar LED
8 PC bushing, V2 flame retardant
9 Latching mechanism
10 PC, V2 flame retardant
11 Silicon seal ring
12 CNC button: Stainless steel/Aluminum
13 Nickel plated hexagon nut
14 Silicon seal ring
15 H57/59 copper chrome plating, aluminum
Schéma bouton dimensions et câblage
Characteristics
Product type Monostable push button 1NO1NC
Screw thread diameter 19mm
Max panel thickness 13mm
Total dimensions 35*⌀25 mm
LED Color: White
Voltage: 9-24V
Number of pins 5
Voltage / Current 250VAC / 3A
Mechanical life 800000 cycles
Reference life 40.000 hours
Operating temperature -30°C, +80°C
Insulation >= 1000mΩ
Dielectric strength 1000VAC min
Condition New
LED Color White
Number of positions 1
Button type 1NO1NC
Avis
Comments (0)
No customer reviews for the moment.
€6.50LB Aluminium Push Button with...
