IAN CANADA LINEARPI PRO DUAL Ultra-Low Noise Linear Power Supply Module +/-12V
Regulated Power Supply
Reference 19916
Bon à savoir
The LinearPi Pro, an evolution of the Linear Pi MKII, is an ultra-low-noise linear power supply capable of delivering high currents. This is the dual model corresponding to reference #38D. This regulated linear power supply is able to deliver 3 different voltages: 5V(default), 3.3V and 12V. Its ability to deliver a current of 5A makes it the perfect ally for modules requiring high currents, such as the Raspberry Pi5.Including €0.05 for ecotax
Last items in stock!
- Paiement sécurisé
Ce qu'il fait
Ian Canada LinearPi Pro Dual Ultra-Low Noise Linear Power Supply Module +/-12V
The LinearPi Pro, an evolution of the Linear Pi MKII, is a Ian Canada ultra-low-noise linear power supply capable of delivering high currents. This is the dual model corresponding to reference #38D. This regulated linear power supply is able to deliver +/-12V. Its ability to deliver a current of 5A makes it the perfect ally for modules requiring high currents, such as the Raspberry Pi5.
Key points and improvements of the IAN CANADA LinearPi Pro :
- 5A continuous output current
- Ultra-low output impedance of 2.5mOhm
- AC DC input mode for best possible sound quality
- Very low noise level 0.8uV
- Parallel output architecture
- 4-layer PCB with double copper thickness and additional shielding layers
- Total filtering capacity 29080 uF
- Large heat sink
- SMT PCB assembly process
- Several LinearPi Pros can be grouped into a large power supply system using the integrated isolated master/slave on-off control signal chain
LinearPi Pro
Linear Pi
Output current
5A
2.5A
Total filtering capacitance
29080uF
13640uF
Architecture
Parallel power stages
Single power stage
PCB
Four layers double thickness copper high current PCB with two additional shield layers
Two layers double thickness copper high current PCB
Ultra low noise
0.8uV RMS rated
Actual noise could be even lower because of the parallel power output stages and the additional shield layers
0.8uV RMS rated
Heatsink
25 x 50 x 50mm
15 x 50 x 50mm
Schottky rectifiers
High speed, ultra-low drop
High speed
IAN CANADA LinearPi Pro Dual: excellent transient response
One of the key features of the Linear Pi Pro Dual is its transient load response. Indeed, when the load current varies from 1A to 5A, the noise level remains extremely low and the output voltage drop does not exceed 10mV. With output impedance limited to 2.5mOhm (@1kHz), the linear Pi Pro can be considered one of the best-performing low-noise linear power supplies on the market.
| Specifications | |
| Product type | Linear power supply module |
| Output voltage | +/-12V DC |
| Output current | 5A |
| Rated noise | 0.8µV |
| Recommended input voltage | 12V configuration: 15VDC or 6V AC |
| Transformer recommendation chart | ||
| Voltage configuration | Working current | Transformer P/N or equivalent |
| 12V | 0-3A | 1182M12 or 1182P12 |
| 0-2A | 1182L12 or 1182M12 | |
| General | |
| Dimensions | 132 x 115mm |
| Mouting holes spacing | 115.5 x 108mm |
| Condition | New |
