Audio Switch Board Jack 3.5mm 2 to 1
Switching Module
Jack 3.5mmJack 3.5mm PCB Connector
Reference 16672
Bon à savoir
This switching module is equipped with two 3.5mm jack connectors at the input and a single 3.5mm jack at the output. Thus, it allows using an integrated button to select an active source among the two inputs to redirect it to the output. The module also has an XH2.54mm connector to add a second output connector.
€2.90Tax incl.
2 years warranty
  • Paiement sécurisé
Ce qu'il fait
Audio Switch Board
Jack 3.5mm 2 to 1
Module commutateur audio Jack 3.5mm 2 vers 1
Product type Audio switch board
Inputs 2x Jack 3.5mm
Outputs 1x Jack 3.5mm
1x Analog output on XH2.54mm connector
PCB dimensions 42 x 29.5mm
Condition New
Input Jack 3.5mm
Output Jack 3.5mm
PCB Connector
Avis
Comments (0)
No customer reviews for the moment.
€2.90Audio Switch Board Jack 3.5mm...
