Input Selector Module CS8416 4 SPDIF Inputs to 1 I2S Output with LCD Screen
Switching Module
Solder padI2S
Reference 12505
Bon à savoir
This kit includes an LCD screen and a SPDIF/AES to I2S/Left Justified source selection module. It will be an excellent basis for the design of a DIY system.
€24.90Tax incl.
Including €0.01 for ecotax
2 years warranty
Last items in stock!
  • Paiement sécurisé
Ce qu'il fait
input selector Module with LCD SCreen
SPDIF (Coaxial, USB, Optique AES) to I2S
écran lcd avec selecteur de sources
This kit includes an LCD screen and SPDIF/AES source selector to I2S/Left Justified. An excellent basis for the design of a DIY system.
The selector module has one AES input and 3 inputs in SPDIF format (USB, Coaxial, Optical). For example, it will allow you to add a source selection to an I2S DAC and, at the same time, to take advantage of the screen display for greater ergonomics.
Warning: Only the source selector module and screen are delivered. Cables and jumpers are not delivered.
SPDIF Chip Cirrus Logic CS8416
Inputs AES
SPDIF : USB, Coaxial, Optical
Outputs (Jumper for selection) I2S
Left Justified
Control Possibility to install a button (not supplied) for source selection.
LCD Screen Blue isplay, 65m x 14mm
Power supply DC 5V (not included)
Screen module fixation hole spacing 75 x 31mm
Screen module dimensions 80 x 36.5 x 17mm
Input selector module fixation hole spacing 42 x 42mm
Input selector module dimensions 48.5 x 48.5 x 11.5mm
Connection diagram
Condition New
Input Solder pad
Output I2S
Avis
Comments (0)
No customer reviews for the moment.
€24.90Input Selector Module CS8416 4...
