Single-Ended to Balanced Converter Module XLR / RCA Mono
Switching Module
RCA
XLRPCB Connector
Reference 17314
Bon à savoir
This mono single-ended to balanced converter module allows you to retrieve a single-ended signal via its RCA or XLR inputs to output a balanced audio signal on XH2.54mm connector.€25.90Tax incl.
2 years warranty
- Paiement sécurisé
Ce qu'il fait
Single-ended to Balanced converter
XLR / RCA Mono
This mono single-ended to balanced converter module allows you to retrieve a single-ended signal via its RCA or XLR inputs to output a balanced audio signal on XH2.54mm connector. It includes two low noise JRC5532 dual OPAs mounted on DIP8 brackets, which can be easily replaced according to your preferences. In addition, the power supply section of the module includes two Nichicon 2200µF 35V filter capacitors and two L7912CV voltage regulators to provide a clean and stable electrical signal to the other circuits.
| Specifications | |
| Product type | Single-ended to balanced converter |
| Channels | Mono (1) |
| Inputs | 1* Single-ended mono RCA 1* Single-ended mono XLR |
| Output | 1* Balanced mono output on XH2.54mm connector |
| OPA | 2* JRC5532 |
| General | |
| Supply voltage | 12V-0-12V AC (power supply not included) |
| Dimensions | 103*76*25mm |
| Condition | New |
| Input | RCA XLR |
| Output | PCB Connector |
Avis
Comments (0)
No customer reviews for the moment.
€25.90Single-Ended to Balanced...
