Switching Power Supply Module 700W +/-30V
SMPS Power Supply
Screw terminalsPCB Connector Screw terminals12.0 30.00.5 6.5220.0 230.0 240.0SMPS
Reference 15592
Bon à savoir
This LLC switch mode power supply module has a main output delivering ±30V. The resonant circuitry uses a high frequency sine wave, ensuring excellent stability and a clean power supply. The power supply is also equipped with an independent output of 12V 0.5A and an auxiliary output of ±12V 0.5A.
€49.90Tax incl.
2 years warranty
  • Paiement sécurisé
Ce qu'il fait
Module d'alimentation
Alimentation à découpage 700W ±30V
Module d'alimentation à découpage 700W ±30V
The power supply is also equipped with an independent output of 12V 0.5A and an auxiliary output of ±12V 0.5A. The latter allow the supply of less demanding devices, such as a fan. The module accepts an input voltage of 200-240V AC.
The module also benefits from a protection system against overheating, overcurrent and short circuits.
If a protection system is activated, the module locks up. It is then necessary to disconnect the AC power supply and wait for the filter capacitor voltage to drop to 0V before restarting.
The current of the independent and auxiliary outputs cannot exceed the current delivered by the main output.
Product type Switching power supply
Input 200-240VAC on screw terminals
Output voltages Main output : ±30V 6.5A
Independant output: 12V 0.5A
Auxiliary output : ±12V 0.5A
Accuracy of voltage stabilization ±3% @ 220VAC
Continuous power 350W
Rated power 700W
Peak power 900W
Efficiency Max. 98%
Dimensions 96 x 96 x 38mm
Weight 310g
Condition New
Input Screw terminals
Output PCB Connector
Screw terminals
Output voltage (V) 12.0
30.0
Output current (A) 0.5
6.5
Input voltage (V) 220.0
230.0
240.0
Power Supply SMPS
Avis
Comments (0)
No customer reviews for the moment.
€49.90Switching Power Supply Module...
