Bon à savoir
The Douk Audio MC303 is a passive XLR selector with 3 inputs and 3 outputs. The contacts of the XLR connectors are gold-plated for perfect signal transmission and increased resistance to corrosion and oxidation.Including €0.05 for ecotax
Last items in stock!
- Paiement sécurisé
Ce qu'il fait
Douk Audio MC303 Passive Audio 3 to 3 XLR Selector Switch
The Douk Audio MC303 is a passive XLR selector with 3 inputs and 3 outputs. The contacts of the XLR connectors are gold-plated for perfect signal transmission and increased resistance to corrosion and oxidation. Switches, meanwhile, feature silver-plated contacts. The MC303 allows you to select 3 different sources and 3 different outputs, for maximum listening flexibility. For example, you can connect a DAC, CD player and DVD player, and then output the signal to a preamplifier, amplifier or passive speakers.
The Douk Audio MC303 is compatible with most audio devices. However, if common ground noise exists, please add an isolation module between the MC303 and your device.
Douk Audio MC303 overview
| 1 | Input selector |
| 2 | Output selector |
| 3 | 3x XLR output |
| 4 | 3x XLR input |
| Specifications | |
| Product type | Passive XLR selector switch |
| Inputs | 3x XLR stereo female input |
| Outputs | 3x XLR stereo male output |
| Housing material | Aluminum |
| General | |
| Dimensions | 280 x 124 x 80mm |
| Weight | 1kg |
| Color | Black |
| Package | 1x Douk Audio MC303 |
| Condition | New |
