ISOACOUSTICS APERTA SUB XL Subwoofer Stand 368x406x37mm 72kg Black
Speaker Supports
Reference 18981
Bon à savoir
The Sub Aperta XL prevents the physical transfer of energy to the subwoofers support surface as well as the return of vibrations to the subwoofer thanks to its patented IsoAcoustics soundproofing. This innovative product sets a new standard in soundproofing with its sleek design and aluminum frame. This technology will allow you to avoid disturbing your neighbors while keeping bass with greater clarity and definition.Including €0.05 for ecotax
- Paiement sécurisé
Ce qu'il fait
ISOACOUSTICS APERTA SUB XL Subwoofer stand 368x406x37mm 72kg Black
The IsoAcoustics Sub Aperta XL subwofer stand prevents the physical transfer of energy to the subwoofers support surface as well as the return of vibrations to the subwoofer thanks to its patented IsoAcoustics soundproofing. This innovative product sets a new standard in soundproofing with its sleek design and aluminum frame. This technology will allow you to avoid disturbing your neighbors while keeping bass with greater clarity and definition.
Innovative low profile shape
The innovative shape of the Aperta Sub XL allows it to be positioned directly under the subwoofer enclosure without interference with existing stands. Its dimensions 368 x 37 x 406 mm provide acoustic soundproofing with a discreet design. It is designed for use with front and side firing subwoofers weighing up to 72,5kg. As a bonus, the mat discs are included and provide a solid connection to the mat and a solid base for your subwoofers.
Better bass with noise reduction
The insulators are directional and are designed to be positioned with the logo facing forward. This allows you to overcome the lateral deviation and oscillations which will bring more precision to your bass. This results in clearer low frequencies, cleaned of their muddy sound, which will allow you to enjoy your music or your movies without disturbing the neighborhood.
| Specifications | |
| Product Type | Subwoofer stand |
| Dimensions | 368 x 37 x 406 mm |
| Max load | 72.5kg |
| General | |
| Color | Black |
| Package | 1x Aperta Sub XL 4x mat discs |
| Condition | New |
| EAN13 | 0810514001277 |
