TRIANGLE S05 Speaker Stands Light Gray (Pair)
Speaker Supports
Gray
Reference 19002
Bon à savoir
Triangle S05 speaker stands are designed for bookshelf models. They provide excellent stability and optimal speaker positioning. With a height of 62cm, the Triangle S05 speaker stands enable you to place your speakers at ear height for optimum diffusion of your music.
€279.00Tax incl.
Including €0.05 for ecotax
2 years warranty
  • Paiement sécurisé
Ce qu'il fait
Triangle S05 Speaker Stands Light Gray (Pair)
Triangle S05 : Light gray speaker stands
Designed to accompany HiFi speakers, the S05s benefit from a robust design optimized to absorb speaker vibrations. The 18 x 29.5cm top plate is capable of supporting the vast majority of bookshelf speakers weighing up to 25kg. An anti-slip coating ensures that speakers stay in place.
The aluminum center tube ensures perfect structural rigidity and helps absorb vibrations. A grommet system at the rear of the tube allows discreet integration of your speakers into your audio system. The stand can also be weighted with fine sand or steel balls (not supplied) to enhance sound performance.
Elegant and modern, Triangle S05s boast a magnificent design. The bottom shelf is finished in high-temperature molded glass. It is also fitted with height-adjustable steel decoupling spikes. Rubber feet are also available, depending on the floor covering.
Product type Speaker stands
Height without spikes 620mm
Height with spikes 640mm
Base dimensions (W x D) 260 x 320mm
Top plate dimensions (W x D) 180 x 295mm
Grommet Yes
Decoupling spikes Yes
Height-adjustable steel spikes or rubber studs
Ballast foot Yes
Steel beads sold separately
Total dimensions (L x H x P) 260 x 620 x 320mm
Weight 9kg / stand
Color Light gray
Condition New
Color Gray
EAN13 3660216011312
Avis
Comments (0)
No customer reviews for the moment.
€279.00TRIANGLE S05 Speaker Stands...
