TRIANGLE LUNAR 1 Vinyl Turntable 33/45 RPM Ortofon OM-5E Green
Vinyl turntables
Reference 19611
Bon à savoir
The Lunar 1 turntable from Triangle is a manual turntable designed to play 33 and 45 rpm vinyl records. It features excellent build quality and is assembled in Europe in partnership with Pro-ject Audio.Including €0.05 for ecotax
- Paiement sécurisé
Ce qu'il fait
The Lunar 1 turntable from Triangle is a manual turntable designed to play 33 and 45 rpm vinyl records. It features excellent build quality and is assembled in Europe in partnership with Pro-ject Audio. Drive is via a flat belt, and playback is via a lightweight, low-friction aluminum tone arm specially optimized for the Ortofon OM-5E cartridge. With its distinctive Triangle aesthetic, the turntable matches perfectly with the brand's various speaker ranges. An RCA phono interconnect cable with HP-OFC copper conductors and gold-plated connectors is supplied with the Lunar 1 turntable.
TRIANGLE LUNAR 1: high-density wood base
The Lunar 1 features a base made of high-density fiberboard (25kg/m3) and an ABS polymer top. These materials absorb vibrations and prevent unwanted resonance, guaranteeing pure sound.
TRIANGLE LUNAR 1: an easy-to-use turntable
A switch on the side of the turntable makes it quick and easy to select the rotation speed between 33 and 45 rpm.
TRIANGLE LUNAR 1: Ortofon OM-5E cartridge
At the end of the aluminum arm of the Triangle Lunar 1 turntable is an Ortofon OM-5E cell with an elliptical diamond profile. The elliptical diamond profile generally allows for a greater level of detail and a better reading of high frequencies.
TRIANGLE LUNAR 1: HP-OFC copper phono interconnect cable
The phono cable supplied features HP-OFC copper conductors and gold-plated RCA plugs for enhanced conductivity and resistance to corrosion and oxidation.
| Specifications | |
| Product type | Vinyl turntable |
| Turntable type | Manual |
| Drive system | By belt |
| Playback speeds | 33 and 45 RPM |
| Cartridge | Ortofon OM-5E |
| Diamond type | Elliptical |
| Tone arm type | Straight |
| Tone arm material | Aluminum |
| Tone arm length | 21.5cm |
| Cartridge output voltage | 4mV |
| Fréquency response | 20hZ-20kHz |
| Output | 1x Stereo phono RCA (with ground terminal) |
| Cable | RCA phono interconnect cable (HP-OCC and gold-plated connectors) |
| RCA cable length | 1.2m |
| General | |
| Power supply | 5V DC |
| Dimensions | 420 x 330 x 112mm |
| Weight | 3.5kg |
| Color | Green |
| Package | 1x Triangle Lunar 1 turntable 1x Flat belt 1x Dust cover 1x RCA Phono interconnect cable |
| Condition | New |
| EAN13 | 3660216011909 |
