Audio Transformer E-9818 600:600
Audio Transformer
Reference 19646
Bon à savoir
This E-9818 600:600 transformer can be used for a variety of tasks. For example, you can use it to convert a balanced signal into a Single-ended signal and vice versa, or to isolate an audio signal from the rest of the circuit and thus avoid the parasitic noise generated by the latter. With its near-perfect decibel variation of just +/-0.18dB over a frequency range of 20Hz to 20kHz, you can rely on this transformer to deliver Hi-Fi quality. Furthermore, the E-9818 600:600 transformer comes complete with PCB, so compatibility with the system in which it will be installed is assured.
€17.90Tax incl.
2 years warranty
Last items in stock!
  • Paiement sécurisé
Ce qu'il fait
Audio Transformer E-9818 600:600 (Unité)
E-9818 audio transformer
Audio E-9818 transformer dimensions
Wiring diagram
Product type Audio transformer
Transformation ratio 1:1
Spacing betwen pins 5mm
Spacing between rows of pins 12.5mm
Frequency response 20Hz - 20kHz
Loss across transformer ±0.18 dB
Dimensions 22 x 22 x 18mm
Weight 30g
Package 1x Audio Transformer E-9818 600:600
1x Compatible PCB
Condition New
Avis
Comments (0)
No customer reviews for the moment.
€17.90Audio Transformer E-9818 600:600
