RAMM AUDIO E72 Interconnect Cable OCC Copper Ø8mm
Balanced Cables
Reference 15903
Bon à savoir
The Ramm Audio E72 modulation cable offers excellent design quality for perfect signal transmission. It features two conductors, each consisting of three 0.5mm OCC copper strands, combined with four PP tubes filled with air as dielectric and an aluminum-mylar shield. The E72 also has a drain wire, composed of three 0.65mm OFC copper strands.Available now
- Paiement sécurisé
Ce qu'il fait
Ramm Audio E72
Interconnect cable OCC copper Ø8mm
The Ramm Audio E72 modulation cable offers excellent design quality for perfect signal transmission. It features two conductors, each consisting of three 0.5mm OCC copper strands, combined with four PP tubes filled with air as dielectric and an aluminum-mylar shield. The E72 also has a drain wire, composed of three 0.65mm OFC copper strands. The filling uses cotton. Then comes a general aluminum-mylar shielding, followed by a flexible and robust PVC sheath.
Ramm Audio cables comparison
Elite 8
Elite-XTRA
Elite 72 (E72)
Mozart2
Cable geometry
Air-Inside© geometry with multi-layer shielding for excellent transparency and resolution, with less distortion and noise
Conductors
Single-core OCC copper
Number of conductors
3 individually shielded conductors
2 individually shielded conductors
Conductor composition
3 wires of 0.65mm, 0.60mm and 0.55mm individually wrapped in silk thread
2 x 0.5mm PP-insulated wires
3 x 0.5mm bare wires
1 x 0.6mm bare wire
Drain wire
3 x 0.6mm OFC monocrystalline copper strands
3 x 0.5mm OFC monocrystalline copper strands
1 x 0.65mm OFC monocrystalline copper wire
Dielectric
Cotton filling
PP rods
Cotton filling
PP rods
Cotton filling
PP rods
Cotton filling
Conductors shielded by copper foil
Capacitance (pF/m)
140
203.51
203
155
Resistance (Ω/m)
0.024
0.03274
0.033
0.028
Inductance (µH/m)
1.4
1.31394
1.32
1.25
Characteristics
Natural, pure and transparent sound with smooth musicality and exceptional sound image. Quiet, excellent noise and interference rejection
Clean, natural signal transfer for dynamic performance with better-defined deep bass and smoother highs
Musical, transparent and smooth with excellent sound image
Sound image with highlighted voices. Natural sound with low distortion and noise
Connectors
Balanced connection, usually XLR
Single-ended connectors, usually RCA
Outer diameter
9.2mm
9.2mm
8.2mm
9mm
| Specifications | |
| Product type | Interconnect cable |
| Conductor material | OCC Copper |
| Conductors diameter | Ø3mm |
| Conductors section | 2x1.7mm² |
| Dielectric | PP Tubes |
| Shielding | Aluminium-Mylar foil |
| Drain wire | OFC Copper |
| External sheath | PVC |
| External diameter | Ø8mm |
| Color | Black |
| Condition | New |
| Diameter (mm) | 8.0 |
| Number of conductors | 2 |
| Insulation material | Polypropylene (PP) |
| Shielding | No |
| Section (mm²) | N/A |
| Conductors Plating (Cable) | None |
| Ground / Shielding | Yes |
