WBT-0735 Speaker Terminals Makrolon Insulated 24k Gold-Plated (Set x4)
Binding Posts
Reference 2304
Bon à savoir
WBT-0735 speaker terminals are 24k gold-plated and polished for maximum resistance to corrosion and oxidation. They meet the most demanding signal transmission requirements, thanks to a meticulous overall design.Last items in stock!
- Paiement sécurisé
Ce qu'il fait
WBT-0735 Borniers Speaker Terminals Makrolon Insulated 24k Gold-Plated (Set x4)
WBT-0735 speaker terminals are 24k gold-plated and polished for maximum resistance to corrosion and oxidation. They meet the most demanding signal transmission requirements, thanks to a meticulous overall design. In fact, they provide a high-pressure contact level and feature full Makrolon insulation. In addition to providing the most effective insulation, Makrolon is a plastic with excellent impact resistance, making WBT-0735 speaker terminals extremely durable. All these features enable them to accept large cable cross-sections while maintaining excellent conductivity. An integrated clamping system protects the banana plugs from accidental disconnection. Puzzle plates (mounting insulators) complete the package for simplified installation. WBT's Safety Line series is designed for the discerning hobbyist or professional.
If you are using WBT-0735s for bi-wiring and wish to combine them with WBT-0725 short-circuit bridges, the terminal blocks must be mounted separately, i.e. without the connecting tab. Make sure to maintain a minimum distance of 30 mm (terminal center to terminal center). The distance to the second pair of terminal blocks must be exactly 60 mm.
| Specifications | |
| Product type | Speaker terminal |
| Conception | Monobloc |
| Contact material | Copper alloy 68% |
| Contact plating | 24k gold |
| Insulation | Makrolon |
| Compatibility | Banana plugs 4mm 6 or 8mm spades Bare crimped wire |
| Max. conductor cross-section | External: 6mm² (9 AWG) Internal: 10mm² (AWG 7) |
| Internal connection | Crimping or welding |
| Max. panel thickness | From 0.5 to 10mm |
| Identification ring | 2x red 2x white |
| General | |
| Gross weight | 208g |
| Package | 4x WBT-0735 speaker terminals |
| Condition | New |
| Mounting type | To screw |
| Connectic | Female |
| Max panel thickness (mm) | 10.0 |
| Accepts Banana Plugs | Yes |
| Connector | Speaker terminal |
| Contacts Material (Connector) | Copper Alloy |
| Contacts Plating (Connector) | Gold |
