THINKYA R01 CD and USB Audio File Player Bluetooth 5.2 Bidirectional 16bit 48kHz
CD Players
Reference 20031
Bon à savoir
The Thinkya R01 is a CD and audio file player with a retro look. It features a SILAN SC6137D processor and a precise laser head. In addition to allowing you to play your CD library via a 3.5mm jack line output and Toslink optical output, a 3.5mm jack headphone output is also available. This headphone output is driven by a G Class amplifier stage capable of driving headphones and IEMs with impedances from 16 to 32 ohms.Including €0.05 for ecotax
Available now
- Paiement sécurisé
Ce qu'il fait
Thinkya R01 CD and USB Audio File Player Bluetooth 5.2 Bidirectional 16bit 48kHz
The Thinkya R01 is a CD and audio file player with a retro look. It features a SILAN SC6137D processor and a precise laser head. In addition to allowing you to play your CD library via a 3.5mm jack line output and Toslink optical output, a 3.5mm jack headphone output is also available. This headphone output is driven by a G Class amplifier stage capable of driving headphones and IEMs with impedances from 16 to 32 ohms. Added to this is bi-directional Bluetooth 5.2 functionality, enabling a wireless signal to be received, for example, from a smartphone with streaming platforms, or sent wirelessly to a Bluetooth speaker. In addition, a USB-A (USB Disk) input lets you connect a USB stick, and accepts a wide range of formats: FLAC, APE, WAV, AAC. The whole unit is powered via USB-C port and features a 2000mAh battery for 6h autonomy.
Thinkya R01: Bluetooth 5.2
A special feature of the Thinkya R01 CD player is its two-way Bluetooth capability. Not only can it act as a Bluetooth receiver, but also as a transmitter. This can be particularly useful for people with wireless speakers.
Thinkya R01: USB-A port (Disk)
A USB port lets you use a USB stick as a source, and accepts high-definition formats: FLAC, APE, WAV, AAC.
Thinkya R01: 2000mAh battery
The Thinkya R01 is powered by a 5V/1A DC USB-C port. In addition, a 2000mAh battery provides up to 6 hours of autonomy.
Thinkya R01: vintage look
This CD player has a wooden body for a very attractive effect. There's also a fader-operated digital volume control.
Thinkya R01 remote control
An infrared remote control is supplied for a pleasant user experience. Tone control of bass and treble is available via the remote control.
Thinkya R01 overview
| 1 | CD player |
| 2 | Control buttons |
| 3 | Volume control |
| 4 | Screen |
| 5 | Power on |
| 6 | Optical Toslink output |
| 7 | USB-A input (USB Disk) |
| 8 | Jack 3.5mm headphone output |
| 9 | Jack 3.5mm line output |
| 10 | USB-C charging port |
| Specifications | |
| Type de produit | Lecteur CD et de fichiers audio USB |
| Processor | SILAN SC6137D |
| Inputs | CD player 1x USB-A (USB Ddisk) Bluetooth |
| Outputs | 1x Optical Toslink 1x Line output 3.5mm jack 1x 3.5mm jack headphone output Bluetooth |
| Bluetooth version | Bluetooth 5.2 bidirectional |
| Supported formats | CD : CD-DA, CD-R, CD-RW, MP3 USB : FLAC, APE, WAV, AAC |
| Supported sample rates | PCM up to 16bit 48kHz |
| SNR | > 80dB |
| Recommanded headphone output impedance | 16-32Ω |
| Tone control | Treble : ±10dB Bass : ±10dB |
| General | |
| Power supply | 5V DC 1A via USB-C |
| Standby consumption | < 0.5W |
| Battery | 2000mAh |
| Full battery charge time | 3h |
| Battery life | 6h |
| Dimensions | 195 x 160 x 43mm |
| Weight | 630g |
| Package | 1x Thinkya R01 1x USB-A to USB-C cable 1x 3.5mm jack to 3.5mm jack cable 1x IR remote control |
| Condition | New |
