HIFIBERRY DAC8x DAC Board for Raspberry Pi 5 Burr Brown 24bit 192kHz
DAC and Interface Modules
Reference 19621
Bon à savoir
The HiFiBerry DAC8x is a high-resolution digital-to-analogue converter for the Raspberry Pi 5. It is a special sound card for the Raspberry Pi, optimised for a specific use case: high-quality audio playback at an affordable price.€85.00Tax incl.
Including €0.05 for ecotax
2 years warranty
Available now
- Paiement sécurisé
Ce qu'il fait
HiFiBerry DAC8x DAC Board for Raspberry Pi 5 Burr Brown 24bit 192kHz
Key features:
- 8-channel audio output.
- Four 192kHz/24bit Burr-Brown DAC chips.
- Direct connection to the Raspberry Pi, no additional cables required.
- No soldering required, it comes in the form of a prefabricated kit. All you have to do is plug it into your Raspberry Pi.
- Compatible with all Raspberry Pi 5.
- Directly powered by the Raspberry Pi.
- Two ultra-low-noise linear voltage regulators for optimum audio performance.
- HAT compliant, EEPROM for automatic configuration.
- Supplied with all the components needed for assembly. 4 M2.5x12mm spacers to fix the board to the Raspberry Pi.
| Specifications | |
| Product type | DAC Board for Raspberry Pi |
| Input | GPIO 40 pins |
| Outputs | 4x Jack 3.5mm TRS |
| Compatibility | Raspberry Pi 5 |
| Max output voltage | 2.1Vrms |
| Signal-to-noise ratio (SNR) | 112dB |
| Total harmonic distortion more noise (THD+N) | -93dB |
| Frequency response | 10Hz - 70kHz (-3dB) |
| Supported sampling rates | PCM up to 24bit 192kHz |
| General | |
| Consumption | < 0.3W |
| Dimensions | 55 × 65 × 25 mm |
| Weight | 30 g |
| Package | 1x HiFiBerry DAC8x 4x M2.5x12mm spacers |
| Condition | New |
Avis
Comments (0)
No customer reviews for the moment.
€85.00HIFIBERRY DAC8x DAC Board for...
