TOPPING B200 Power Amplifier Mono Discrete 200W 4 Ohm Black
Power amplifiers
Reference 19588
Bon à savoir
The Topping B200 power amplifier is a mono amplifier based on a discrete-component NFCA amplifier circuit. This enables it to achieve a considerable power level while maintaining excellent performance metrics. Indeed, the B200 is capable of delivering up to 200W of power (THD=1%) at both 4 ohms and 8 ohms.
€599.00Tax incl.
Including €0.05 for ecotax
2 years warranty
Available now
  • Paiement sécurisé
Ce qu'il fait
Topping B200 Mono Discrete Power Amplifier 200W 4 ohm Black
Topping B200 picture
The Topping B200 power amplifier is a mono amplifier based on a discrete-component NFCA amplifier circuit. This enables it to achieve a considerable power level while maintaining excellent performance metrics. Indeed, the B200 is capable of delivering up to 200W of power (THD=1%) at both 4 ohms and 8 ohms. It boasts a dynamic range of 145dB and an extremely low level of distortion. Interface-wise, it's straight to the point, with three balanced XLR/6.35mm jack combo inputs (accepts both XLR and 3.5mm jack connectors) and a speaker terminal output. A two-level gain control adjusts the output. The whole unit is housed in an attractive, solid aluminum case.
Topping B200 highlights
Topping B200: new discrete NFCA amplifier circuit
The new NFCA amplifier module enables the B200 to develop 200W of power at 4 ohms load and 8 ohms load. All with very low distortion (<0.000075%) and an extended dynamic range of 145dB.
Photo of NFCA amplifier circuit
Photo of the Topping B200 12V trigger
Topping B200: 12V trigger and gain control
The B200 features a 12V trigger that automatically switches on when your Hi-Fi system is switched on. In addition, a two-level gain control allows the B200 to adapt to different configurations and speakers: low gain 11.6dB and high gain 22.0dB.
Topping B200 overview
1 ON/OFF button and source selector
2 Input source indicator LED
3 3x Balanced XLR/Jack6.35mm input
4 Speaker terminal output
5 Firmware update port
6 Gain adjustment
7 Power connector
8 Trigger In 12V
Example of HiFi configuration with two B200
Topping B200 video review by AudioScienceReview (Amir)
Product type Power amplifier
Amplification NFCA amplifier circuit with discrete components
Channels Mono
Inputs 3x Balanced XLR/Jack6.35mm combo input
Output Speaker terminal block
THD (@1kHz, A-wt) <0.00008% @ 4Ω 5W
<0.000075% @ 8Ω 5W
THD (@20-20kHz, 90kBW) <0.0005% @ 4Ω 5W
<0.0004% @ 8Ω 5W
SNR (A-wt) 145dB
DYnamic range (@1kHz, A-wt) 145dB
Frequency response 20Hz-40kHz (+/-2dB)
20Hz-100kHz (+/-0.4dB)
Output level 80Vpp @ 4Ω
110Vpp @ 8Ω
Measured noise level AP (A-wt) <2.3uvrms G=L
<3.9uvrms G=H
Input sensitivity <12.5uvrms G=L
<3.9uvrms G=H
Gain 11.6dB @ G=L
22.0dB @ G=H
Output impedance <5mΩ
Output impedance 10KΩ
Output power 200W @4Ω THD+N<1%
240W @8Ω THD+N<10%
200W @8Ω THD+N<1%
Minimum load impedance
Color Black
Dimensions 22x 18.5 x 9.2mm
Package 1x Topping B200 power amplifier
1x Mains adapter 64V 4A (3 poles GX connector)
Topping B200 measurements
Condition New
EAN13 6977577361039
Avis
Comments (2)
Grade 5/5
No customer reviews for the moment.
€599.00TOPPING B200 Power Amplifier...
