Input Selector Board 4 Channel with Display and Remote Control CS3310
Preamplifier modules
RCAXH 2.54mm2 (Stereo)
Reference 15009
Bon à savoir
This module consists of a source selector with 4 stereo RCA inputs and an analog output on a 2.54mm XH connector, as well as a VFD display. The management of the audio streams is entrusted to a Cirrus Logic CS3310 16bit chip.
€49.90Tax incl.
2 years warranty
Last items in stock!
  • Paiement sécurisé
Ce qu'il fait
Module sélecteur de source 4 canaux avec afficheur et télécommande
This module consists of a source selector with 4 stereo RCA inputs and an analog output on a 2.54mm XH connector, as well as a VFD display. The management of the audio streams is entrusted to a Cirrus Logic CS3310 16bit chip, ensuring low distortion. The display can show 9 digits and a potentiometer on its right side allows to switch on/off the module, to select an active source or to adjust the volume level. The supplied remote control also allows remote access to these functions.
Module sélecteur de source 4 canaux avec afficheur et télécommande Module sélecteur de source 4 canaux avec afficheur et télécommande
The connector near the relays is in parallel with RCA input 1 (IN1). If you have an internal source such as a Bluetooth module, you can assign it to IN1 (the RCA input is then no longer usable).
The P5 connector allows you to modify the maximum output level.
P5 ON : 31.5dB maximum output level.
P5 OFF : 0dB maximum output level.
The P3 connector corresponds to the memory mode at start-up.
P3 ON : Start-up state on IN1 and level at -46dB.
P3 OFF : Start up at the last state with switch off.
The J1 connector allows a manual control by button (a contact to the ground of each line is enough).
MUTE : Mute mode.
1-2-3-4 : Direct selection of inputs 1, 2, 3 and 4.
V- : Volume -
V+ : Volume +.
Product type Input selector module
Inputs 4x Stereo RCA
Output 1x XH 2.54mm analog output
Display VFD
Remote control (2x AAA 1.5V batteries required, sold separately)
Frequency response 20Hz - 20kHz
Rated current 500mA
Control mode SPI
Channel crosstalk -130dBFS
Dynamic range -120dB
THD+N 0.0004% @ 1kHz
Power supply 12V AC (sold separately)
Input selector board dimensions 177 x 59mm
Input selector board mounting holes spacing 144 x 31.5mm
Display board dimensions 168 x 37.5mm
Display board mounting holes spacing 161 x 30.5mm
Weight 200g
Package 1x Input selector board
1x Display
1x Remote control
1x Audio output cable
1x Interface cable for selector/display modules
1x Button (random color)
Condition New
Input RCA
Output XH 2.54mm
Channel 2 (Stereo)
Avis
Comments (0)
No customer reviews for the moment.
€49.90Input Selector Board 4 Channel...
