€32.90Tax incl.
2 years warranty
Last items in stock!
- Paiement sécurisé
Ce qu'il fait
R-core transformer
This R-CORE transformer is ideal to build a power supply for a DAC or a preamplifier.
It has 2x115V as primary widing. As long as the appropriate wiring is made, it can be used on the European power grid as well as the American grid.
Two secondary windings each provide a voltage 9VAC with a maximum current of 1.66A. Moreover, it is equipped with a magnetic screen and an electrostatic screen.
Each cable is identified by a different color code. This color code is detailed on a label found directly on the body of the transformer.
Dimensions of the transformer
The values of the secondary voltages of the transformers are the nominal load voltages. The no-load voltages will be slightly higher than those stated.
| Specifications | |
| Type | Step Down Transformer |
| Format | R-Core |
| Power | 30VA |
| Primary winding (input voltage) | (230) 0-115V 0-115V |
| Secondary winding (output voltage) | 0-9V (1.66A) 0-9V (1.66A) |
| Dimensions | 79 x 68 x 39mm |
| Cables | Flexible 200mm |
| Weight | 0.68Kg |
| Mounting plate | Provided Pre-installed |
| Condition | New |
| Primary voltage (V) | 2x 115.0 |
| Secondary voltage (V) | 9.0 |
| Power (VA) | 30.0 |
Avis
Comments (4)
Grade
No customer reviews for the moment.
€32.90R-CORE Transformer 30VA 2x9V
