Source Selector Board 4 Inputs
Switching Module
RCAPCB Connector2 (Stereo)
Reference 15005
Bon à savoir
This source selection module has 4 stereo RCA inputs and one output. A rotary selector is used to select an input / ouput (work both ways). A series of 4 LEDs indicates the active source.
€28.90Tax incl.
2 years warranty
  • Paiement sécurisé
Ce qu'il fait
4 Inputs with Light indicators
Module sélecteur de source / contrôle de volume 4 entrées
This source selection module has 4 stereo RCA inputs and one output. It can also work the opposite way : 4 outputs and one input. A rotary selector is used to select the active input/ouptut. A series of 4 LEDs indicates the active source. The module is powered by 12-15VAC.
A Bluetooth receiver module (not included) can be connected via a 3-pin connector. In this case, the 4th RCA input must remain unused.
Product type Input selection board
Inputs 4x Stereo RCA
1x Bluetooth input (optional, Bluetooth module sold separately, replaces 4th RCA input)
Output 1x Analog output on 3-pin connector (cable to bare wires included)
Supply voltage 12-15VAC on screw terminal (power supply sold separately)
Input/output module dimensions 120 x 45mm
Potentiometer module dimensions 50 x 30mm
Potentiometer shaft diameter Ø6mm (notched)
Condition New
Input RCA
Output PCB Connector
Channel 2 (Stereo)
Avis
Comments (0)
No customer reviews for the moment.
€28.90Source Selector Board 4 Inputs
